Hello everyone. I have 2002 3.5 L V6 engine intrepid and for the past couple months I have been having a wierd problem happen to me while I am driving. Randomly, the air bag light will come on, and the ac, windows, turn signals, and front latch will shut off. Once I start the car again they will usually work but then they will still shut off again randomly minutes later. Sometimes I can go a couple days without this happening but it will eventually do it again. What does everyone think the problem is? Is it electrical or maybe the ignition? I don't have to use my car to drive to work or anything so i've been putting this off for while but it has been happening so often lately that I need to do something about it. Thanks for any help!
Check the ignition fuse with a meter and or just replace it! Mine was in an accident and I had the same problem replaced that fuse and problem solved! If not check your grounds start with the ones at the junction box under the hood
I checked and all the fuses are fine! I noticed that it i wiggle the key forward a bit while driving everything comes back on, but the left signal blinks rapidly. Any other thoughts as to what it could be?
There is another trend with the same problems looks like an ignition switch! As far as the fast blinker that's an indicator for a burnt out bulb!
