I have a coolant leak coming from a housing that is below the alternator close to the bottom of the engine. This housing has 2 hoses going into it. Any idea on what it is? Is this the thermostat?
That is the thermostat housing you describe, but likely it is leaking from the water pump weep hole that is right next to the housing. If you look up from underneath, there will be a hole drilled into the block right next to the housing.
Check that hole first, if no coolant is leaking, then check the hoses connecting and that housing itself.
