Have my dodge Intrepid for about 2 years now. Love it . It's great
On Thursday when the temp was about 5 below 0, I try to start it with my remote start as I have been doing for a year. The car won't start.
I discover that one of the Plug Cap is burnt. I change it and still It won't start.Everything seems OK. I put gas treatment into my gas and it start. After an hour, It burnt the same plug cap and this time it also burnt the Computer that control the Spark. I ordered it from the Junk Yard. I should on Friday.
Question: Does anyone knows of this or what may have cause this to happen? PLEASE HELP...ANY ADVISE WILL BE MORE THAN WELCOME
Thank You
By plug cap do you mean your coil packs? Which engine do you have? Sure seems like you have a strange electrical problem by all of these burnt parts. I have no answer right now myself. Keep us up to date.
Donnie
that is odd, can't think of anything that would cause that with a circuit like a spark plug has, seems like a short where the wires get really hot from having so much current put through them.
but spark plugs are pulsed... strange.
Mopar or No Car
Before installing the new PCM (computer) and coil pack I'd check the wiring between the two very carefully. It may have been a bad PCM that made it happen in the first place but it could also have been some kind of short in the wiring ...
I will definitely double check all wires before installing the computer.
Please any more advise will be really appreciated
Thank You
