Hello everyone
:smileyvault-newhere
A little about me:
I just got into the driving world and I got my moms old 2002 Dodge Intrepid R/T (sat for nearly 2 yrs).
Great car, fast, good looking (being re-painted in spring), leather, remote start etc
The problem:The heat in the car is not nearly as hot as it should be on the high setting, i remember it used to be hot, now its just warm, and being in NY, i need the heat as hot as possible!. It does not overheat (I can drive it all over and the temp stays steady), and was wondering if there could still be a bubble? Not really sure so any help would be great that. also btw when in park the rpm wont go above (i wanna say 4 thousandish but i cant recall now) is this normal? In drive it can rev fully. Thanks!
you'd never make it here then.
your heater core is probaby in need of a flush, clearing any debris that might be impeding flow.
of course, that is assuming that your temp guage does come up to a proper operating temp. if not, then you may be in need of a thermostat.
get off my lawn
or from sitting ,, it could be a little low and have some aiir in it, temp guage going about half way up?thats about the normal range
I'd agree on the thermostat. if it's maybe stuck open low coolant level or heater core clogged . do the simple items first i.e checking level of coolant then on to air in system then to replacing stat.
