81 - 100 of 110 Posts
These are on the front Andrew? I think I recently put on a moog on my front end when I did my 300m Special swaybar during my engine swap.. I can double check the records at work and get you a part number, they seem fairly heavy duty. Cant remember what they are for sure tho...
Discussion Starter #82
Curious...
Did you install the black Sensatracs or the blue Economatics??
Black Sensa Tracs, although I think they use the same mount part number regardless.
Yeah, they're on the front. I wondered about Moog. I talked to a Moog rep before and he told me that they aren't rebranded Monroes, that they are built under contract by someone else for them.
I'm guessing you should've used OEM strut mounts and Bearings! I did a test fit of a Monroe bearing on an OEM strut and it had high clearance. That lead me to buy OEM strut bearings and there were no issues with clearance.
The FSM clearly states the difference between the left/right OEM mounts and how they should be installed. Take a look at that. There have been more than one instances where people have installed OEM strut mounts & bearings on Monroe/Moog "Quickstruts" with some success.,
Discussion Starter #84
You're right, I was apprehensive about putting Quick Struts in because of the issues with the Monroe mounts, but I had the Quick Struts installed as is because I was in a pinch and couldn't wait for the dealer to get OEM mounts in. Looking back, maybe I should have kept the old mounts. The struts may have been rotted out, but the mounts were still quiet!
Its funny, I recall the FSM stating the mounts are two different part numbers, yet all aftermarket mounts, as I recall, are one. I asked that Moog rep why, he didn't have an answer (big surprise).
My bad, I thought you were talking about end links on the front. I did OEM strut mounts when I had my drop springs installed
The reason I asked about the color of the quickstrut is because myself and another 300Mclub member have installed the cheaper blue economatics and neither he or I have had any issues so far. His have been on for about 1 year...mine for about 3 months. And everyone that I have seen on these forums with issues has installed the black ones
Discussion Starter #87
I just got off the phone with Monroe, they told me as of January 2012 the bearing design was changed for the mounts. I got mine October 2011 so I would have the old design. Who knows, maybe this new design will actually last for more than a year.
Discussion Starter #89 (Edited)
Weird thing is that the mounts for both the Econo-Matics (blue) and the Quick Struts (black) use mount 903901. Did the Economatic come out last year or are they an older line than that? I wonder if they've been using the newer design and there's still Quick Struts manufactured before 2012 in inventories with the old design.
Nice trep! Looks very close to mine other than mine is an ES and has the 3.2 I had a starting problem so I just upgraded the injectors from the stock two hole spray pateren to a four hole and gained some ponies under the hood!
still looks good. nice car Andrew!
Discussion Starter #96
Been a while!
Nice looking car Andrew! So the front struts to buy are Monroe Parts #181667 and #181668 ? Also should you have a alignment done after changing them?
I realize this is over a year old, but in case you were still wondering: yes those are the correct numbers. If you buy them, throw out the Monroe mounts and reuse or buy OEM mounts/bearings. As has been said many times on here, Monroe strut mounts/bearings for these cars are awful. Replaced them twice before buying a set of used OEM units. Problem free since.
Anyway, what's all happened to this car since the last update...
Well the suspension is in pretty good shape all around now. Fronts were sorted out by replacing the Monroe mounts/bearings with OEM units, and during the original installation it got new sway bar links and bushings.
After that the car was unfortunately rear ended over the summer, but was not totaled and they did a good job repairing it. The rear bumper lines up better than it ever has!
After that was taken care of I purchased rear Quick Struts and sway bar links. I was planning to do this myself, but I discovered through research that while the fronts aren't too bad to do (only took a couple hours to change out the front mounts), the rear struts seem to be a real PITA. After reading about sheered bolts and the assinie way these things are bolted to the car, I elected to have them professionally done. They took 4 hours and lots of heat, but my mechanic got them out without breaking a single bolt. My only problem wit these Quick Struts is the car sits higher out back than it used to and more than the fronts do. I wonder if this is normal for these? Still, it rides so much better now.
The next big item was doing a transmission service. I've never done it, but I figured it was as good a time as any. The fluid wasn't burn or black, but it definitely looked well used. No flushing, as I've heard unpleasant things happening as a result of that. Instead I just dropped the pan, cleaned it (normal amount of metal on the magnet), cleaned the pan, replaced the filter, and put new fluid in. Now its nice and pink-ish. Transmission seems a bit more responsive too.
One night my truck release wouldn't work. I pulled the wiring harness apart and found not one, but two broken wires. Fixed both and my truck light began working for the first time since I've owned the car!
Had the joy of replacing the driver's side downstream O2 sensor recently. That was just awful. They are so far up under the car with so little room to get tools around them. I spend more time getting tools to fit on it than anything else. And that was with a lift! Couldn't imagine doing it on the ground. At least it wasn't seized. Popped a new NTK sensor in and all was good.
I haven't really had time for any more big projects, however I did fix a couple vacuum leaks it had, one from the hose feeding the LDP (had to fix it twice) and found a leak at the corner of the plenum.Not junkyards had one, so I used Permatex black plastic weld to fix it. Seems to be holding.
Finally, I noticed my PCV hose was soft `n squishy (and oily). My car doesn't have the funky heat exchanger, but finding the OEM hose was proving to be a challenge. Instead, I opted to replace it with my own construct.
Clamps came from a hardware store. The brass adapter came from Advance. The tricky part was acquiring 5/8" and 1/2" fuel rated hose. Heater hose that size is easy to get but doesn't hold up against oil. I was able to get both from Carquest though. They even say "Fuel Vapor >PCV/EEC<" on them and are much stronger, thicker and kink resistant than heater hose is. I ran the 5/8 hose from the PCV valve and put the adapter just before the nipple on the engine. I had thought to use a couple 90° fittings, but the hose is strong enough where it doesn't seem like it will kink. If it does I'll add a couple elbows.
Cost me about $10, and I have enough leftover hose to make another one.
That's pretty much it for this year. Soon it'll be time for winter hibernation. Next year I plan to swap out the dash, as mine has two big cracks in it now and it's driving me crazy. While doing that, I'd also like to change the carpet out for a black one.
I'd like to get the roof repainted, as the clear coat is slowly pealing from the trouble area by the driver;s door.
I think its getting to be time for new lift supports front and back.
Need to replace the tie rod adjusting sleeves before the next alignment.
I'd like to replace the coolant reservoir with a nice new one at some point.
And that's pretty much it for high priority items. Almost at Almost to 219,000 now. We were going to take it to KS this week to visit family, but foul weather canceled those plans, a bummer. Her last big trip for the year will probably be to CT a few hours away for vacation.
How's everyone else doing?
Discussion Starter #98
Still at Advance?
Yeah, pay, its steady and benefits aren't bad. I freelance design on the side and fix lawn mowers in the spring/summer as a hobby/side money. Busy busy.
Haven't done too much with the car, just keeping her clean and happy. I still have lots of plans when I'm able to get to it. Chief among which is body work. There's small bubbling above the rear bumper on the driver's side and a tiny bit on the passenger side wheel well. The paint clear coat issue on the roof by the the driver's door has gotten slowly worse. These are top priority after some big changes this summer. I also plan to swap out 3 of the 4 doors as they are showing signs rust along the seams. I should gain access to rust free cars soon, so it'll be easier just to replace them. The under body isn't bad, but there's surface rust along the pinch welds I want to clean and repaint.
Finally, I still want to do some big interior changes, but they aren't critical and thus remain lower on the list. Plus, I'm missing 2 door panels to make it work. If I acquired those I'd probably do the interior swap first since its easy, just can't find any taupe Intrepids around here.
