<div align=center>
Updated 8/15/06
<p>
</div>
If you have a question about anything I've done, you can just reply here
<p>
Current Mods:
Drivetrain & Performance
<UL>
<LI> Dana 44 Rear Axle
<LI> Powertrax D44 LockRight Locker
<LI> K&N Drop-In FilterCharger
<LI> GDI 3-Core Radiator
<LI> Tom Wood's Heavy Duty Rear Drive Shaft
<LI> Hood Spacers
<LI> Yukon 4.88 Gears w/ Master Install Kits & Open Carriers
<LI> Spicer D30/D44 1310 U-Bolt Yokes
<LI> M.O.R.E. Bombproof Motor Mounts
<LI> AWShifting AW4 Manual Shift Kit
<LI> Alloy USA D30 Axle Seals
<LI> Alloy USA Chromoly D30 Outer Stub Axle Shafts
<LI> Yukon 4340 Chromoly D30 Inner Axles
<LI> Longfield Dana 44 Super Joints
<LI> Alloy USA Dual Drilled D44 Chromoly Axle Shafts
<LI> Powertrax Dana 30 Zytanium Cross Shaft
<LI> NP231 Transfer Case
<LI> TeraFlex NP231 2LO kit
<LI> PORC HD 231 SYE
<LI> Aussie D30 Locker
</UL>
Suspension & Steering
<UL>
<LI> Rear Swaybar Removed
<LI> JKS Bar Pin Eliminators (Rear Upper)
<LI> Rubicon Express 1.25" Greasable Lift Shackles
<LI> Rubicon Express 4.5" Leaf Springs
<LI> M.O.R.E. Rear Bumpstops (1" Extended)
<LI> Rubicon Express 4.5" Coil Springs
<LI> Rubicon Express Rear Stainless Steel Extended Brake Line
<LI> Rubicon Express Front Stainless Steel Extended Brake Lines
<LI> JKS Adjustable Lower Control Arms
<LI> JKS Adjustable Upper Control Arms
<LI> OME XJ Long Travel Front Shocks
<LI> DPG Adjustable Rear Bumpstops
<LI> ORGS Adjustable Coil Spacers
<LI> Currie Heavy Duty Steering
<LI> JKS Bar Pin Eliminators (Front Bottom)
<LI> Rubicon Express 4* Steel Shims
<LI> ORGS Raised Rear Shock Mounts
<LI> ORGS Swaybar 2" Raised Mounts
<LI> Goferit Offroad Tie Rod Flip Insert
<LI> Gabriel Rear Shocks
<LI> T&T Customs Track Bar Bracket
<LI> T&T Customs Custom Track Bar
<LI> Intrepid4x4 Fab Trackbar Brace
</UL>
Wheels & Tires
<UL>
<LI> Interco TrXus 33x12.5x15 MT Tires (Set of 5)
<LI> Tech-1 RockCrawler 15x8 Black Wheels w/ 3.75 Backspacing (Set of 5)
<LI> Bart-Loc Beadlocks (All 5 Wheels)
</UL>
Armor, Structural Support & Recovery
<UL>
<LI> WARN Receiver Shackle Bracket
<LI> Mopar Gas Tank Skidplate
<LI> C-ROK Steering Box Frame Plates System
<LI> M.O.R.E. Steering Box Brace
<LI> C4x4 Tapered Front Winch Bumper
<LI> C4x4 PreRunner Bar
<LI> ORGS LCA MiniSkids
<LI> Warn XD9000i Winch
<LI> Spicer D44 Heavy Duty Cover
<LI> Formatt Fabrications Tube Doors
<LI> Warn D30 Differential Guard
<LI> Warn D44 Differential Guard
<LI> Cooter/Intrepid4x4 Fab Cage
<LI> Intrepid4x4 Fab Cage Mounted Spare Tire Carrier
<LI> T&T Customs Stiffeners
<LI> PMW Upper Quarter Guards
<LI> T&T Customs HD Bellypan
<LI> Formatt/Intrepid4x4 Fab Replacement Boxed Rockers
<LI> nth Degree Oil Pan Skid
</UL>
Electrical Stuff (Batterys, Lighting, CB, Stereo, etc...)
<UL>
<LI> Optima Red Top Battery
<LI> J&C Heavy Duty Battery Cables w/ Quick Disconnects
<LI> PIAA 520 Ion Fog Lights
<LI> Cobra 19 DX III Compact CB Radio
<LI> Firestik II 4 Foot CB Antenna
<LI> Jensen MP3510 CD/MP3 Headunit
</UL>
Misc. Stuff
<UL>
<LI> Intrepid4x4 Fab Storage Box
<LI> YJ Driver's Side Mirror
<LI> Removeable Rear Doors
<LI> Herculined Interior
<LI> Mopar Exhaust Heat Shield
<LI> Xtreme Seat Covers
<LI> Hi-Lift 48" Jack
<LI> Husky Front Floor Liners
<LI> Hayden Power Steering Cooler
<LI> Formatt Fabrications 10lb CO2 Tank & Guard w/ Adjustable Regulator
<LI> Formatt Fabrications 10lb CO2 Tank Mounting Bracket
<LI> Chopped Top
</UL>
In Progress:
<UL>
<LI> Cowl Snorkel (Not Installed Yet)
</UL>
Reversed and Abandoned:
<UL>
<LI> Dunlop 30x9.5 Radial Mud Rovers
<LI> 5 Foot Firestik CB Antenna
<LI> JKS Front Top Shock Conversion
<LI> DPG Swaybar Disco Holders
<LI> Rusty's 2" AAL Lift Kit
<LI> JKS Quicker Disconnects (Stock to 2" Lift)
<LI> Mopar Transfer Case Skidplate
<LI> Rusty's Hydro Steering Stablizer
<LI> Midland 77104XL CB Radio
<LI> Dana 44 Heavy Duty Cover
<LI> Mopar Front Skidplate
<LI> JKS Quicker Disconnects (4" to 6" Lift)
<LI> OME ZJ Long Travel Rear Shocks
<LI> C4x4 D30 Differential Guard
<LI> Kevin's Track Bar Conversion
<LI> C4x4 Swing Away Tire Carrier
<LI> C4x4 License Plate/CB Antenna/Flag Bumper Mounts
<LI> Rock Lizard Fabrications Gila Monster Lower Quarter Guards
<LI> Full Size XJ Gear Steel Tail Light Boxes
<LI> 2x4 Custom Rock Rails
<LI> C4x4 Rear Bumper
<LI> Removeable Front Doors
<LI> Skid Row Transfer Case Skidplate
<LI> ORGS Adjustable Track Bar
<LI> Tom Wood's NP242 SYE
<LI> OME Steering Stabilizer
<LI> Powertrax D30 LockRight Locker (Broken)
<LI> Rock Lights
<LI> HiddenHitch Class III Rear Receiver
<LI> C4x4 Shackle Brackets
<LI> DynoMax Super Turbo Cat Back Exhaust System
</UL>
<p>
Website:
www.myXJ.net.com
Updated 8/15/06
<p>
</div>
<p>
Current Mods:
<UL>
<LI> Hood Spacers
</UL>
<UL>
</UL>
Wheels & Tires
<UL>
</UL>
<UL>
</UL>
<UL>
</UL>
Misc. Stuff
<UL>
<LI> Chopped Top
</UL>
In Progress:
<UL>
</UL>
<UL>
<LI> Rock Lights
</UL>
<p>
Website:
www.myXJ.net.com
