1 - 2 of 2 Posts
Is there a way to test the sun sensor without having it installed?
Just curious as I have a new one and would like to see if it works before I put it in and then find out my problems is with the wiring. BTW I have one of those voltmeter but do not have clue how to use it. :grlaugh:
Do you have a multimeter? If so, you can measure the resistance between the 2 pins that are for the sensor(not the 2 for the alarm led). The resistance should vary depending on how much light it is exposed to so if you are in bright light and put your finger over the sensor eye you should see a noticeable change.
1 - 2 of 2 Posts
