I have a 01 intrepid 2.7. Had two o2 codes(2 pre-catalyst) and changed them tonight(got them from the dealer). Left battery disconnected one hour, started and drove approximately 2 miles. Still have the same codes and car sputtered and stalled.
Please help me!
I just paid this penalty and am expected to have inspected so I may renew tag.
Please help me! :fun_84:
I need to know EXACTLY what codes you are getting to determine the nature of the o2 sensor related problem.
Now it could be a fuel system problem or an electrical problem, only the exact code will help me now.
Thanks for replying!The codes are po134 and po154.
The car was not behaving in this way prior to the o2 change. It is undrivable-after about 5 minutes of driving-car continuously sputters,stalls. I think maybe the dealer sold me bad sensors.
I can't find P0134... but P0154 is:
O2 Sensor 2/1 Signal Inactive - niether rich or lean condition is detected from the oxygen sensor 2/1.
I'd check the contacts / wires at the sensors.
It would seem that you're not getting 02S heater element faults, either they are working or the "no signal" code over-rides the heater element codes.
The connection looks fine- why would the car start behaving in this way only after I put on the new O2s?
Would a diagnostic at my dealer tell me the exact problem? I am running out of money.
P0134
P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
Sounds like a dead sensor!
Other Things
If the sensor turns out to be good, check the fuses. On some cars the PCM is served my multiple fuses, strange I know.
If that checks out, get a tester and check the continuity between the connector to the sensor and the connector at the PCM, you WILL need a wiring diagram for this.
If the harness check out OK, the sensor is good and the PCM is getting power, then you have a malfunctioning PCM.
oh God. I wouldn't know how to check all that wiring, I suppose I will take it for diagnostics. My account is so empty though. For now, in order to drive it, I am going to put the old sensors on.
Thanks for the info!
