I have had my Clarion TV in the trep for about 2 years now and i just started to blow fuses.I'm running the power wire to the Lighter/Ign/batt fuse block. and i have the ground to a bolt in the metal dash frame inside the fuse panel. I don't know what this could be. Anyone have any ideas?
This is going to sound stupid but have you checked the in line fuse on your TV? or checked to make sure a wire has not been exposed behind the dash? Also when I had my TV I had my ground to the metal plate right below the two din slots. just a couple of things to think about hope you find the problem.
What fuses are you blowing, the inline ones on the TVs or the main circuit fuse in the OEM fuse block? The only reason for a fuse to blow is too much current draw. I would start unplugging things and make sure nothing is wrong with the equipment. If fuses continue to blow then you're probably looking for an exposed wire somewhere...
the OEM fuse block is where it's blowing. I'll have to check the inline fuse tonight.
Well, if the OEM fuse block fuses are blowing then the problem lies between the inline fuses and the OEM fuse block...
So I checked into the wire problem and come to find out i had some exposed bare wire in the dash. it was it. it's back to normal now. thanks for everyones help.
