1 - 10 of 10 Posts
OK I have looked through all the old posts and still can't find any answers.I have a 93 es and I can't get the remotes to program.I have tried jumping the trac switch,but nothing happens.I have the rke module under the upper part of the dash and I am assuming it is working because the doors auto lock when rolling.The only other problem I might have is that the remotes are the wrong ones.Does anybody know how to tell if the remote is the correct one for my car.The remote model/fcc # is abod3d3t.My trep is one of the very early models built in 93(before 6/93).Any ideas?
:devil:
you could try ebay and spend $10 to try to eliminate the possibility of bad remotes, you can usually find remotes for just about anything on ebay. got my spare remote from there for 10 bucks.
:devil:
The only problem I have with going to e-bay to buy them is I am afraid I will end up in the same boat I am in right now.How do I know they are selling me the correct remotes?
The earliest remotes from '93, and I believe '94, had an outline of a car with the trunk open on the 3rd button. '95 and up got a different receiver in the dash along with a 3rd button on the fob with the words "press twice" and a very small pic.
Which one(s) do you have?
The remotes I have have 3 buttons.1 shows a key and says lock.Next to it shows a car with the trunk open.Below them button only says unlock.
I have a 93 Vision and if you are looking at the remote from the top it says unlock with an arrow pointing up, then to the right lock with an arrow pointing down, and below those two in the middle is a picture of a car with the trunk up. then below that is the pentastar. Hope this helps
That almost sounds like an aftermarket remote. Does it have the Chrysler pentastar on it?
They don't have the pentastar,but I know they are from a Chrysler product because I remember getting them before the car went to auction.I just don't remember exactly what kind of car it was.Guess I will try to track down another one and see if it works.Thanks for the help guys.
>They don't have the pentastar,but I know they are from a Chrysler product ..
They may be from a Mitsubishi with Dodge or Chrysler badging, in which case they're probably not compatible.
newyorker1985 has described what you need to find. I have 2 here, pm me with your email addy and I can take a picture of 1 and send it to you.
remote p/n
the part number you are looking for on a '93 intrepid is 4469341. i am in the process of getting remotes myself. this is the p/n the dealer gave to me for my '93 chrysler concorde
1 - 10 of 10 Posts
