1 - 2 of 2 Posts
Are the 192 and 212-2 bulbs interchangeable? The replacement guides at sylvania.com list both bulbs. The 212-2 *may* be a 'rough duty' bulb for vibration-prone locations like doors, etc.
Which bulbs go into the map lights in a 2G EVIC/OTIS console? 192 or 194? If 192, does that pesky 212-2 also fit? I'm assuming that the same bulb for the EVIC/OTIS map lights also fits the rear seat reading lights in an ES.
thanks
The 192 is stock for maplights, the 194 works as well. Different bulbs have different candle power, thus different heat range. 3 CP is the recommended bulb for the maplights.
1 - 2 of 2 Posts
