I just recently got into an accident and aside from the body issues, everything seems to work okay except for the A/C. The collision was in the rear as well as in the front right of the car. Anyone have any idea why the A/C would have stopped working?
Refrigerant leak, broken belt, bad compressor or clutch, broken transducer.
Maybe obvious stuff that's already been checked, but it's a start.
More details on what you have or have not checked ?
Sounds like a leak if the blowers are working. Something could have been jarred loose. Have the system pressure tested and pray that its not the evaporator.
Hmm, unfortunately my hood is jammed shut, and even if it wasn't, I'm absolutely clueless on how to check these things. I think a broken belt may be obvious to the eye though. I am in the process of getting the hood un-jarred
I sure hope not either! I read a tiny bit about those! x.x
If it got smashed hard enough to jam the hood, it don't sound good partner, sorry.
Once you get the hood open, turn on the A/C if the belt's still intact (yes, it will be obvious).
I'm not sure if these cars have low pressure switches or not (prevents the A/C from working if the system is low on charge).
If not that will tell you if the clutch and compressor are still working.
Also look for excess oil sprayed in a certain area (refrigerant oil, not engine oil), for indications of a bad hose/line or other such leak.
The transducer is on the right side as well. I can only see mine from the botton looking up.
Sort of a round two wire connector plugged onto a switch installed in a fitting on the line going to the condenser.
I read somewhere they were prone to failure, so I went to the yard and picked up three.
The first one brought my A/C back online, so I think I still have 2 if you need one (no gaurentee on if they work or not though, I've not tested them to see).
As an aside, the blower working is not a good indication of the A/C (or heat for that matter) status or condition.
If it works it blows air, hot, cold or otherwise. That only means the motor and associated circuitry is intact and working.
