Just wanted to let everyone know I finished replacing my factory bulbs with PIAA's, they fit as good if not better than the factory XS models. The only difference between the two is the 9006XS (OEM) has a 90 degree boot, the 9006 is straight.
How-to:
remove two screws holding in headlight assembly
pull assembly out of car
turn socket holding OEM bulb
pull off connector
attach new bulb
turn connector to lock
reattach headlight assembly using same two screws
I also changed my H3 foglight bulbs, just as easy
remove screw
pull foglight assembly
undo clip holding bulb
pull wire
attach new wire (straight blade style) into factory round connector
reattach clip
reattach assembly
the bulbs make a world of difference
[ January 29, 2002: Message edited by: joekd ]
How-to:
pull off connector
attach new bulb
remove screw
pull wire
reattach clip
reattach assembly
