Ok guys we tried to do the atc swap and something went wrong (as you can read in my earlier post) so we decided to put the original harness and mtc back in. We reconnected everything the way it is supposed to be and put the car back together. Now we have a couple of problems;
1. Car is in limp mode and wont shift out of second!
2. Cluster has the squares on all of the gears.
3. MTC wont shturn off at all and we cant turn the defroster on.
4. When shifting the car stutters as if it has a rough time getting into the gear.
5. The speedometer is not working
6. Lastly the only code we get is code 1698. Which is a TCM code.
Anybody ever encounter this kind of problem before? Any ideas on what is going on here? We think it might be the BCM but not sure. Any help is much appreciated. Thanks
Tom
Tom
