1 - 10 of 10 Posts
I have a 1994 Intrepid 3.5L engine with a very loud knocking sound coming from the valve cover and runs rough. Did a search on the knocking noise; the best I can come up with is a rod knocking or piston slap. Can someone please explain what this is and if this can be fixed.
Thanks,
Leonard
Since no one has replied yet to your post i guess i'll say something. Doe syour engine have high mileage? Rod knocking is when you get a vibration because there is too much wear somewhere between the crakshaft and the piston. It could be bearings, loose wrist pins, etc.
Piston slap....? don'[t know. valves hitting the piston could make a sound like that i think. 3.5L has a timing belt. how does the car run? is it possible that you could've jumped teeth? how long has it been since timing belt has been changed?
hopefully someone with more experience jumps in to answer in more detail.... anyone??
Thanks,
Leonard
Sounds like time for a new engine or car. At least the tranny is still working.
Timing belt sounds about right. If it is that you will have a problem. My uncel used to get cars with timing belts until he met his mustang.
Engine has 140,000 miles.......anyone have some idea, maybe lower end of engine or heads.......timing is ok
thanks
Leonard
Well, my 1997 ES has 145 thousand on her and not meaning to brag, mine still sounds new....I feel for ya man, real bummer. GOOD LUCK
Thanks Guys.....appreciate your replies
Checked oil level its ok, this is a very loud knocking or banging noise under the hood or car and smokes out the tail pipe ( little ), I removed valve covers and everything seams to be ok, if a rod is knocking what is involved and can I fix it or do we need new engine.
Leonard
i have a 97 and at 123,000 it started a loud knock, at 124,000 it threw 2 rods and punched a hole in the side of the motor. After that i got a remanufactered motor from dodge and that one also threw a rod after 10,000 miles. so i went back to them and they were sorry and replaced it again and said that if i had brought it in when it started to knock than they could have avoided the blow up. so if i were you id take it down to the dealership soon before it blows.
Bottom end is gone, so I'm in the market for a good used engine, I live in Hamilton Ontario
Leonard
1 - 10 of 10 Posts
