1 - 2 of 2 Posts
· Registered
Hey Guys, I am up in Toronto Canada. (OBTW. 93 Concord 3.5 L) It has started to drop below freezing overnight. That sucks alone but... I go to start the Cord today and I hear a very loud Tapping sound. I know what my valves sound like and it wasn't that. It almost sounded like an electrical arc. Very loud and very fast. Well I immediatly shut the car off and check all the fluids. Everything is fine. Restart and sure enough... still tapping. :mad: Well I have to get to work and I am not about to call a cab seeing as I am already late. So I scrape the windows and hop in. Shut it down one more time just incase this will fix it. Luckily it did... the sound stopped. I checked the error codes when I got to work to see if the damned computer knew anything but no luck there. Anyone every heard of this before? It scares the heck of me. Seeing as this is my only means of transportation around this Freakin Metropolis! Any hints will be cool. Thanks guys.
· Registered
Check your plug wires... how long has it been since you replaced all of your plugs and wires? You said something about arcing.
I bought a set of 55 dollar plug wires and that fixed my shaking problem in my car because the 6th cylinder was not firing for about 1.5 months (spent about 1k replacing all this ****, water pump, 6 new fuel injectors [which were going south anyways] and it turns out to be plug wires).
Once i replaced the plug wires and I put some new autolite platinums in there about 1 month before the wires, everything is working A+ now. Trying running some of that engine cleaner through there also and see what that does. :confused:
1 - 2 of 2 Posts
