1 - 9 of 9 Posts
A while back, I posted how much torque to apply to our lugs(ES aluminum wheels). I was told to apply 100lbs of torque. Well, I did a new mod the other day(will post that later), put the tire back on and used my Craftsman torque wrench.
Well, I could barely turn it past 70lbs of torque. So, I am not too sure if 100lbs is right.....just thought I'd let ya'll know.
Haynes says 95 for first gen.
it's a possibilty the tourque wrench needs to be cilibrated. any time you drop or tighten past the preset setting on a tourque wrench...it needs to be recalibrated.
and make sure you are using the proper setting. inch pounds or foot pounds....they are different.
Well, my trusty 01 FSM says that the Aluminum wheel should be torqued to 100 ft. lbs.
My Haynes manual is telling me 100.
Does it matter which wheel on the 2nd Gen? I've got the 2001 R/T "Crusader" rims, which I believe are painted aluminum. I wonder if there's a difference.
not only should they be 100LBS, but check them again in a week, aluminum rims have a tendincy to have the lugs come loose. Odds are it will not happen, but if you want to be percise about it.
It's very important to avoid warping your rotors. Those guys with the impact wrenches can do that if they go nuts on it. Excuse the pun!
I always subscribed to the school of:
Tighten it til it breaks and back it off 1/4 turn.
But, thats just me.... :crazy:
1 - 9 of 9 Posts
