The connector may or may not be there. There's an insert that drops into a recess in the top of the dash - immediately behind the windshield. extends all that from side to side from one A-pillar to the other. Pull the A-pullers off and you should be able to lift the insert out. The connector would be in a recess right in the center of the dash. I believe my '99 2.7 had the connector already there.
I looked at the How-To for the MTC-to-ATC harness hack today on my hard drive. It would be difficult to post - would need to email it to you. If you want that, PM me your email address and we'll go from there. Even if you can get the ATC harnesses you need from your collision repair buddy, and don't need to do any hacking, it will familiarize you what's involved with the conversion. LET ME KNOW.
