221 - 239 of 239 Posts
Discussion Starter #221
Discussion Starter #222
Ok ...small update
I ran into a snag. As I mentioned, I want the tablet to be able to flip down, and allow access to the headunit and/or EQ that will be installed behind it. I did a lot of planning, but didn't take into consideration, that the USB wire and plug that goes into the headphone jack...would stop it from doing so.
I had to choose between a fixed install, Cutting a notch for the wire to pass thru, making the tablet flip inward (didn't want to cut factory mounting holes), or widening the opening. I went with the wider opening.
Here I marked the new opening, and cut it out. I used the pieces I cut out, and CA glued them to the bezel around the tablet. The tacked everything in place, where I wanted.
I started filing in the gaps. I went with the plastic weld method this time. Trying to avoid fiberglass, as much as possible on this. To fill the bottom where the cubby hole went, I used the bottom portion of the factory radio opening...to get a straight line, and retain the same curvature around the corners.
I have 2 more gaps to fill, then I can start on the "flipping" mechanism. It can't be flimsy.
I want the gaps to be real small, but still let the tablet flip freely.
Discussion Starter #225
The B-pillars are now wrapped in black suede to match the headliner, A-pillars, and C-pillars
Added a thin chrome strip to the bottom, to help break things up. Goes well with the rings in the 300M cluster and clock.
Before and After pics
Looking real good, nice touch on the chrome trim.
on a side note, get rid of the b-ball and clean that stuff up. :whistle: HEHE
Discussion Starter #231
Gottaupgrade this thread soon. I have a couple new mods to show.
But it the mean time. I have to get this timing belt replaced. It snapped the other day and hoping for the best. If not, swap time.
I have a question tho. Where can I find the camshaft holding tools? They would make things a lot easier.
In my notes, the "cam lock" is a 8 x 1.25 x 80 mm screw passed through an appropriately sized socket. I forget if you need one or two of these. The passenger side may not need one. This screw through a socket idea certainly isn't factory, but it worked well for me the one time I used it. Besides, the factory cam holder requires access to the rear of the heads, which is not easy.
Discussion Starter #239
As i said on Facebook, looks great! I gotta get to work on updating my thread come to think of it :p
Thanks again..
I said the same thing. What stops me from updating more often on here, is the fact that I can't just upload pics, and have to log into my Photobucket, upload, copy, then paste on here :sneaky2:
