1 - 16 of 16 Posts
Well, this may be just another product review thread, but this stuff actually works!
Here's a picture of it on the trunk. (which has not been cleaned with this before/yet)
How to use:
Personally, I use many paper towels to perform this, and the method to apply is the same as waxing the car, except for the fact that this does not offer any protection/waterproofing that wax does, actually because its an abrasive, it will remove some of the protection that is left. I HIGHLY RECOMMEND WAXING AFTER USING THIS PRODUCT!
And finally for the pictures. I used it on the rear portion only (left side of picture), the front still needs to be done, but that will happen after Mid-Term Exams (Might I just add :ahh:).
Note the scratches on the front (right side) that are not on the finished side (minus wax).
ALWAYS FOLLOW PRODUCT WARNING LABELS
Only problem is that while I tested a few spots by hand it didn't much if anything at all. The scratches on the area i tested were 'filled in' so they appeared darker relative to the rest of the paint but were still there. Only a buffer can really heat the clear coat enough to actually get rid of the scratches.
We have a power buffer, maybe I'll convince my dad to let me use it! :D
Well, I found the power buffer, and as a reward for finding it, I was allowed to use it! Here's the final results the first thing next day. (I'll get better pics when the snow melts)
And the mirrors: I found this and the wiper cowl to be the most interesting "Find"
When New (deer accident is why the mirror is so dirty)
Note the shine
And Now:
i use this stuff when refurbing ATC displays on the clear lens. I also buff headlights with it and wax afterward. You dont need a headlight polishing kit. this is all you need, with a microfiber cloth, and wax.
Discussion Starter #13
This thread is old enough I forget... But I usually get it once every 6 months, and its due again in a few days, but I think I'll just repaint the whole car instead...
Hey, I use this one, too! And you're right. Definitely needs waxing after using it!
I usually use paint sealer after using this product. I find paint sealer way tougher and better compared with regular wax. But still it really depends on the color shade of the paint.
1 - 16 of 16 Posts
