are there any differences between Mobil1 synthetic and Mobil 1 Extended Performance synthetic??? i am about to change my oil, and was wondering if their was any difference at all.
thanks
The extended performance has extra additives that allow you to go longer without a change.
They won't help if you have to change oil due to dust or other junk getting into the motor, the help delay oil breakdown.
With that said, I still recommend that you change your oil on time and certainly, the 15K figure on the extended performance is not for "severe" driving. That 15K figure is based on grandma in her Caddy going down the interstate at a painful 55mph!
k thank you for the info....even though im using synthetic, i still plan on changing my oil around 5000 miles
So I think the consensus is that the regular synthetic is probably what you should be looking at since you plan on doing regular oil changes.
