Status
Not open for further replies.
Some more car audio for sale. A mix of New and Used items. Contact me with any questions.
Got a used JBL GTO CS60.2 2/1 amp and a new JBL 8" GTO804 thub as a kit for sale soon. If you've got a split folding rear seatback or the ski pass-thru in your car this might be the ticket for a little low end. Thub is the same as what was in my 2000 R/T as shown below. The used JBL amp is the lower one in the picture below. The sub would be "free air" unless you build a box behind it. I can supply the manuals with specs for both components. SOLD! Thank You!
Discussion Starter #2
Updated the original post with all the pictures of the actual items for sale.
I always liked your setup aesthetically. How does it perform? how many watts does the amp supply? i understand free air uses less watts. how loud? I wouldnt ask if i wasnt interested.
Here's the specs on the amp:
CS60.2
• 60W RMS x 2 channels at 4 ohms and ²1% THD + N
• Signal-to-noise ratio: 86dBA (reference 1W into 4 ohms)
• 80W RMS x 2 channels at 2 ohms, 14.4V supply and ²1% THD + N
• 160W RMS x 1 channel at 4 ohms, 14.4V supply and ²1% THD + N
• Dynamic power: 160W at 2 ohms
• Effective damping factor: 6.395 at 4 ohms
• Frequency response: 10Hz – 27kHz (–3dB)
• Maximum input signal: 6V
• Maximum sensitivity: 100mV
• Output regulation: – 0.03dB at 4 ohms
• Dimensions (L x W x H): 8-7/8" x 10-1/4" x 2-1/4"
• Fuses: 25A x 1
I thought there was plenty of bass out of that sub without having to crank up the gain. Obviously it wouldn't pound like a pair of 12s or 16s! I'm not into the ghetto trunk rattling bass so for me it was more than enough. Considering this is firing directly into the cabin and not muffled by the seats like a box in the trunk it's pretty efficient. I'm not an audiophile that needs to spend big money.
I should probably post that there's a Sale Pending on it already though!
SOLD! Thank you!
Status
