hey, um ,im about to pull a 2.7 out to drop in a 3.5. will i be able to use the same motor mounts from the 2.7 on the 3.5 high output? i figured probably not, but, might as well ask before i blow $ on new ones.:banghead:
Rubber mounts can be re-used as well as 1 of the brackets. I forget wich one its 2am.
Both rubber mounts can be used. Neither of the mount-to-engine brackets can be used. You have to get the 3.2/3.5 brackets.
