So I have a 2002 Intrepid and was wondering what the mounting depth is for the speakers in the front door. The speakers I'm looking at are a little deep at 3.8" so I wanted to double check they will fit without having to make speaker rings already. I appreciate any help.
Edit: For anyone interested here is a link to the speakers:
http://www.audiosavings.com/product...-6.5-COMPONENT-SPEAKERS-XXX-6.5C/XXX6.5C.aspx
Only way to tell will be to go out and measure. Just unscrew the speaker and stick a ruler in there. I'm not sure if it makes a difference between which type of LH door panel, so I'd just measure it yourself and you know you're good to go.
Discussion Starter · #3 ·
Yeah, I was hoping someone knew what it was offhand. As it turns out, our stock speakers have a mounting depth of about 2", plus about 1/2" or so of clearance, so I guess it's time for me to break out my router and learn how to fiberglass.
Yeah, if you're determined to use those speakers then fabrication is your only choice.
Discussion Starter · #5 ·
I am. I have no problem with fabrication, I just wasn't expecting to do any this early in the build. Plus I am completely inexperienced. Now I need to decide what I want to do to fill in the blank space that will be visible with the stock speaker grill gone.
I haven't gotten to do glassing yet, but I've got my supplies downstairs for my first project. I'm still reading and learning on fiberglassforums.
Discussion Starter · #7 · (Edited)
Well, There are a few very nice guides on SMD:
http://www.stevemeadedesigns.com/board/forum/15-fabrication-fiberglass-etc/
That is their fabrication subsection. I think I have an idea but now I need to decide what color and texture to go with. I'm thinking I may make it then use bedliner on the insert which will be the figerglass. I've never been a fan of the high gloss, so we will see.
Edit: I think I'm going to do 3 layers of MDF, 1st will be a thin ring as a riser, 2nd a larger flat piece to cover everything, the a thicker ring which will be where I mount my speakers. Then I'll stretch the fabric then fiberglass over it. Obviously the process will be more refined but that is the general idea. This way I can take the whole pod out of the door to reinstall factory if I ever have need/desire too.
Let us know when you get pics of this..sounds interesting!
