I am trying to get the names of songs to display on my radio. Some will but most will not. Do I need to save them in any certain format after I download them? Thanks...
Does your radio have that feature? If it does, you need to set the properties of the file. If you are using a PC, right click on the file and click properties, then the summary tab. Fill in all the info. The actual file name that you see while it's in the folder probably won't show up on your display. That should fix ya.
Yes it has that particular feature. i will give it a try when I get home. Thanks alot...
lots of radios only go by the filename. lots of others go by the tag on the mp3. try renaming some of the filenames, or check to see what the tags say. . . .
