I bought the Intrepid new in 2004. It has not been a daily driver, so the miles accumulated slowly. 18 years later it has reached 133,000 miles. I knew that I should have already replaced the timing chain, but I hadn't. In March this year the engine started making a dreadful noise one day and left us stranded when it died. Since then I've accumulated repair and replacement parts and disassembled the portions of the engine necessary to replace the timing chain and water pump. I've also replaced the thermostat and intend to replace the radiator before all this is put back together. During this work I removed the oil pan to inspect the crankshaft bearings. Today, I intended to replace the oil pan. First in this process was to inspect the oil pickup tube by blowing air through it in reverse. Out of that tube came numerous flakes of shiny metal. I no longer have the oil filter which was on the engine at failure so I cannot inspect the filter. It was a K&N HP filter.
In all my disassembly and inspection, I've found no evidence of anything being worn out or broke down other than the primary timing chain tensioner. It was 3 mm beyond its replacement mark.
There was no water in the oil. There was no loss of oil pressure during the failure. The old water pump is in perfect condition. The crankshaft bearings are stable. I tried to move them with my hand and they would not move. The oil was not shiny and the oil pan doesn't have glittery crud in it.
My hope is that the loose timing chain was slapping something and shaving flakes and particles of metal off, which then fell into the oil pan and were sucked up by the pickup tube. I haven't found evidence of that in the form of a clearly worked surface somewhere near the path of the chain.
With the only good evidence I have being that the chain and tensioner must be replaced with new, I plan to buy a new pickup tube and continue re-assembling the engine. I'll use a new Mobil One oil filter with the reassembly. If the engine runs well, I'll be thrilled. The two photos below are the collection of shavings on a shop towel.
