1 - 20 of 46 Posts
:smileyvault-newhere :smileyvault-newhere :smileyvault-newhere :smileyvault-newhere :smileyvault-newhere :smileyvault-newhere :smileyvault-newhere :smileyvault-newhere
First i will say Hi everybody im new on this forum and it seem to be a great place for Trep users.
I bought this Chrysler Intrepid 1999 2.7L yesterday for 2500$ canadian
with 43000 km only lol
last owner was an old women of like 75 year old (i got all bills for all maintenance done from the beginning even each oil change bills !!! its insane)
This car is like new im so happy :p
nice car, thats 1 very low milage trep!
Discussion Starter #11
Someone of you probably know.... for example if bought 18inches wheels for my Trep... should i drop my coils springs like:
1"Front/ 1"Rear
Pro-Kit; Lowering Coil Springs
Brand: Eibach
Part #: 2852.140
or
1.90"Front/ 1.70"Rear
Lowering Springs - Lowering Springs (Front: 1.90 / Rear: 1.70). Fits the Dodge Intrepid, Chrysler 300M, and Chrysler Concorde from 1998 to 2004.
Brand: Sprint Performance Suspension
Part #: 5040
i think with the 1.9 / 1.7 those 18" wheels gonna be really tight in fender ??? idk...
Farticcus of Plenticcus
Nice find....low mileage.
If you want to keep it running tip top, plan to do all maintenance items before you even think of modding the car. 2.7 are maintenance whores, but run well when kept up.
Keep the oil changed on or before the 5000KM mark every time, using nothing but quality filters and oils and that will make the biggest impact on the engine. Check your coolant levels and oil every so often to catch a failing water pump. Do the water pump and timing change every 80K and your set forever IMO. lol
Discussion Starter #15 (Edited)
i was looking the maintenance bills coming with the car and i list them all. Take a look:
Date: KM Job
05/10/2001 13916 injector cleaning 3 in 1, Belt, oil filter, oil, grease,
05/04/2002 15340 hose, transmission cooler hose, oil filter, oil, grease,
10/04/2002 15410 prestone, cart therm, oil pan gasket, bushing rear link, front disk + pads,
01/20/03 18283 battery, air filter,
04/15/03 18802 oil filter, oil, grease, tire balance, bloc heater,
11/21/03 20040 oil filter, oil, grease, belt serpentine (snake)cracked,
11/25/03 20045 antirouille (rust prevention, shooting oil)
12/03/03 20195 re-tighting belt
01/06/04 20469 aquapel windshield
04/16/04 20500 oil filter, oil, grease, paint, cleaning car (lol), wax,
08/25/04 22245 battery, oil filter, oil, grease, injector cleaning,
11/16/04 23509 30km/h door lock bug/repair
05/24/05 24401 oil filter, oil, grease,
11/29/05 26325 front differential maintenance, lube, oil filter, oil synthetic, grease, aquapel windshield, inspection, transmission maintenance, trans oil filter, trans oil change,
11/16/06 29320 oil filter, oil,
28/03/2008 33010 oil filter, oil synthetic, prestone,
06/11/2008 34266 tire, 6 spark plug ngk g-power, pcv valve, soupape rgc,
15/01/2009 34675 battery,
aug/26/09 35945 pmf oil filter, oil synthetic castrol 5w-30, bs switch,
07/06/2010 37900 input speed sensor, oil filter, oil valvoline,
09/06/2010 front link, back link
18/04/2011 39961 oil pressure switch, oil filter, oil synthetic castrol 5w-30
I bought car here for 2500$ Cnd
16/08/2011 43800 oil filter, oil synthetic castrol synthec 5w-30
26/09//2011 44400 4 disks brake + pads, coolant flush
I see one really important maintenance item . Not to say the rest isint. Synthetic oil chage 5w-30. The way i understand it. Someone correct me if im wrong once you use synthetic oil you have to keep using it,it makes a big difference. . Especially if is a full synthetic. I use 10w -30 quaker stat full synthetic and my car runs better. But anyway wecome to the forum. And when the mode bug bites look out . It will be one big adventure. The people on here are very helpful a use the search button for alot of it. But anyway welcome and nice car.
1 - 20 of 46 Posts
