41 - 60 of 80 Posts
Discussion Starter #41
Found a GTX 1050 with a white fan shroud on it for $130. Tempting.
Discussion Starter #42
Also a 1050Ti 3g for $169 and a 1060 3g for $229. Might go with the 1060. PCIe Riser Cable will be here tomorrow so I'll be able to put the video card vertically on the shelf above the PSU as I had originally intended.
Discussion Starter #43
About ready to start my "EVO" build! AMD FX 8320E 8 Core CPU with a CoolerMaster Hyper 212 EVO Air Cooler. 8GB of DDR3 RAM to start. I have an additional 8GB ready to go if I decide it's needed. ASUS 970 Pro Gaming/Aura ATX MoBo. This was originally going in the Thermaltake P3 Snow open case.
Discussion Starter #44
This one will be a "Budget" Performance build.
Discussion Starter #45
Ooops! Wrong orientation of the Heatsink/Fan. Original would've exhausted heat to the top of the case. Moved it so that air exhausts to the back of the case now. Mo Betta!
Discussion Starter #46
Got to love M.2 SSDs! 12 seconds total Boot Time from pressing the Power button to a working Win 10 Desktop.
And that's a "slow" SATA M.2 and not a PCIe M.2 SSD!
Mounted the 3.5" Desktop 2TB HDD..digging out another modular SATA power cable and the i5-7600K build is almost done!
Discussion Starter #47
Did a little Overclocking/Stress Testing on the i5-7100K build running using PCMark 10.
Overclocked to 4.8GHz from stock 3.8GHZ. Max CPU temp was 51 degrees C and GPU temp capped at 52 degrees C with a Modified MSI Afterburner fan profile. Not bad!
CPU sits at 31 degrees C at Idle.
Discussion Starter #48
PCIe Riser Cable came in today for the Thermaltake Snow build. Installed it and moved the video card to it's final resting place. Looks good to me!
Discussion Starter #49
Need to swap out the Blue SATA cable for the Desktop HDD for a black one and tidy up the cabling a little more and it'll be ready for sale.
Discussion Starter #50
Room for another M.2 SSD on the MoBo and 2x 3.5" and 2x 2.5" HDD or SSD inside the case back. MoBo has plenty of open SATA connections for them.
Discussion Starter #51
Assembly of the AMD FX 8 Core has started. MoBo in case and cabling connected.
Discussion Starter #52
Will probably move the AMD R7 370 video card from the Snow build to this FX 8 core build. Then buy the GTX 1060 with the White fan shroud for the Snow build.
Discussion Starter #53
Loading up Win 7 Pro x64 on the AMD FX 8 Core. Then MoBo drivers and MicroCrapola updates. Add my usual Value Added Software Package and verify functionality. Then upgrade to Win 10 Pro and it's updates.
Discussion Starter #54
The AMD FX 8 core build with Red Lighting programmed on the MoBo and Case. Both can be changed to several different colors. More Bling for the $$$. The case lighting "Breathes" while the MoBo lighting is Static but the MoBo lighting programmed to "Breathe" also.
Discussion Starter #55
Win 10 Pro x64 upgrade in progress...dumm-dee-dumm.
Discussion Starter #56
Anyone need an almost new Mini-ITX AMD Quad Core CPU/MoBo/4GB RAM combo for a NAS Box build or cheap compact PC? About to list this on CL for $50.
Biostar A68N-5545 MoBo With Quad Core AMD A8-5545 APU. HD8510D Graphics On Chip.
Samsung 4GB DDR3 RAM 2x2GB.
This Bad Boy Combo sold today. w00t!
Discussion Starter #57
Discussion Starter #58
Probably should list my PC FS stuff in the For Sale thread! Limited exposure here in this thread!
Discussion Starter #59
About to list this "Budget Gaming" PC on Craig's Losers List! Figure $250 for it. Just getting rid of some used/new parts i had laying around.
Hex Core AMD FX CPU
ASRock 970 Extreme3 Mobo
8GB DDR3 RAM
GTX 260 video card
2TB HDD
600W PSU
Thermaltake Versa N21 Case
DVD Burner
Win10 Pro x64 + my usual value added software suite.
Discussion Starter #60
Got an MSI GeForce GTX 1050 DirectX 12 GTX 1050 2GT OC 2GB 128-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready ATX Video Card ordered for the AMD FX 8 core build at $115. Remember this is also a "Budget" build and will be priced accordingly.
41 - 60 of 80 Posts
