This is an issue that has been around for many years, and there are recent posts asking about quick struts. There were some old threads about the problem with aftermarket manufacturers using a universal top strut mount for both the left and right 2nd Gen quick struts, when actually the Mopar left and right mounts have different part numbers and appear different. The threads indicated that this may have caused the problems that many people had with the aftermarket strut bearings failing prematurely and other problems. Perhaps the problem was that there is a necessary left or right tilt between the mount's flange and the center line of the hole, in order to put uniform pressure around the bearing race.
Some people posted that the manufacter's reps they spoke to said they where going to fix this years ago, but the current information on their websites (Moog, Gabriel, etc.) and Rockauto page for all the manufacturers under "strut mount" shows that they are still only listing one universal mount for the 2nd Gen - which is probably what they continued to use on the quick struts (Gabriel, Moog, Monroe, and others).
So to any experts that are still here who posted on those old threads, did the situation ever get resolved, other than people just re-using old Mopar left/right mounts or buying new ones? Today of course any NOS Mopar mounts are very hard to find.
Actually, I think the same situation applies to the 1st Gen mounts, since the Parts Catalog shows that there are different part numbers for left and right, while the manufacturers and Rockauto just list one 1st Gen mount. My impression is that the problem may be less severe on the 1st Gen since that mount is a simpler design, but that is just a guess. A quick search seems that there were/are not as many posts with complaints about 1st Gen aftermarket quick struts. And unlike the 2nd Gen Factory Manual, which has a strong bolded warning and diagrams explaining not switching right and left mounts, my 1994 1st Gen FSM does not mention any of this. Neither does the pdf 1995 FSM posted under the service information subforum.
On both the 1st Gen and 2nd Gen Mopar mounts there are two rubber "tabs" on opposite sides of the hole inside the mounts, and they are oriented differently on the right and left struts when the mounts are installed - 90 degrees different. So they can be used to tell the right and left mounts apart. (On the 2nd Gen 4-stud mounts there is also a rectangular hole that is used to differentiate and orient the left or right mount.) Below is a picture of one of the 1st Gen 3-stud Mopar factory mounts (right I think) showing the tabs. On the aftermarket mounts there either are no tabs, or the tabs on the ONE mount they make are at a similar angle to either the right or left Mopar mount.
So what's the deal? Thanks.
