Ok, so I took a few picture:
Other than it not looking the cleanest in the engine bay, there are a few problems I'm sure are glaringly obvious.
Now onto the story that usually accompanies a series of pictures.
So, I'm going home, moving at a leisurely 50-55mph, when suddenly I was losing speed and my RPM began to shoot up to the max line when stepping on the gas. No matter how much I left off and let on the gas - speed continued to drop until I had to pull over on the side of the road and flip on the hazards. I've never had this problem before and I really didn't know what to do. After waiting for about 5 minutes and contemplating calling a tow company, I tried starting the car up again, and to my amazement it worked, where I was able to safely drive home with no further issue (thanks Intrepid!).
Hopefully, y'all understand my apprehension with wanting to drive this car anymore until I resolve the issue. I'm not the richest gal, but I'm pretty handy with tools and have installed an alternator, rotated the tires, and do all of my engine oil (full synthetic) changes every 6000 miles on this car. Unfortunately, I guess in my 'flow' of doing these small maintenance projects I forgot about the transmission and really should have repaired that PCV hose a heck of a long time ago.
I have google'd the problem and the general result seems to say it's a clogged transmission filter to low transmission fluid. I have really high transmission fluid, as you can see from the pictures and am wondering if this is normal? The car is on 'sort of level' ground where it may be leaning, so that might explain that. But, on the off chance this is a common problem I thought I would put it out there in case someone might know where else that fluid could come from? And finally, what should I do other than a transmission fluid flush and replace the filter? Is this the correct course of action? Does the engine oil and transmission fluid reveal anything, the engine oil always has a little bit of black in it, so sludging is probably going on right? The engine oil always looks filthy when I change it, and it's level stays pretty level with barely burning any between changes.
Sorry for all the questions/ wall of text and thank you to anyone who reads all this and lends me a hand. I appreciate y'all!
