Guys,
I need help with my Concorde. It is 7 years old, but only has 39k miles. I am getting constant shaking on the highway once i get above 50 mph. Sometimes it's barely noticeable, other times quite violent. My hand is visibly moving back and forth on the steering wheel. The front end was aligned and tires were rotated and balanced two months ago. I plan on keeping this car a while, and can't stand when the steering wheel shakes. Here are the questions:
1. Should I replace the original Michelins in hope that there may be flat spots on the 7 year old tires?
2. I have new Moog inner tie rod bushing, but have yet to install. Probably will do this weekend. Should these help?
3. Could it be the wheel bearings, even though it doesn't do it at lower speeds?
4. Should I go ahead and replace lower ball joint/control arm and upper tie rod ends?
I can turn a wrench with the best of them, but don't want to replace stuff that might not need it. I plan on keeping this vehicle for a while.
Thanks for helping with the trouble shooting.
-RB
-RB
