1 - 12 of 12 Posts
How do I get them off to install chrome? :D
I took out all the screws I could see (the ones under the tiny covers too)
What do I do now?
Thanks
You have to take the grill off??????
I didn't see ones around the speaker besides the ones holding the speaker to the door??? Do I need to take those off?
.........rear doors I have all screws out I think (all the visible ones 3 at the bottom of the door, 1 in handle, 1 in other handle........what do I do next??? Just pull??? I tried yanking a bit but it didn't really move much.
take the grill off and look around the outside of the speaker, you will see them there inside holes about 2" deep
If I remember right there were two per door, might be three though
I can tell you're posting right now Joe, thanks for your help in advance :D
Rear doors???
Discussion Starter #7 (Edited)
Gee, thanks Joe & partsguy, such fast response times, you 2 should drive fire trucks :)
Is that all I need to know??? Going outside now, will refresh this thread when I come back if I need more help, thanks again guys :D
Still can't get the rear door off, took out 5 screws total in the rear door (3 under the door and 2 behind little cover ups)
Ummmmmmm, how do I swap the handles out??? OMG looks like it's permanently in there
I need help with the handle removal and the rear door panel removal still, was able to switch the front switches :)
I used a small flathead screwdriver and a pair of needlenose pliers to guide the pins out and pull the OEM handle, install was just a matter of pushing the pin back in with the same pliers
as for the rear panel, run your fingers around the edge to see where it is held in, you should just be able to pull the panels right off
Which way does the OEM handle come out??? I see that I have to slide the top of the handle out, but does it come out the front of the panel or the rear of the panel? did you use the screwdriver to pry the pin away from the socket and then pull or push with the pliers?
Discussion Starter #12 (Edited)
I figured it out!!! I have to break the plastic at the top of the pin so I can slide it out. I didn't realize I had to break anything.
Thanks a lot for all the help, I now have the passenger side done, drivers side tomorrow :)
Thanks again Joe, I might have to let you win in a race with the rental :D
1 - 12 of 12 Posts
