i installed hids in my 02 Intrepid and the guy i bought it from recommended the things that cause it to not flicker, ok i bought them.. upons having those hooked up with it it blew my fuses to the lo beam, did not know that so i tried hooking them up to my highs... turns out it broke thosetoo. So i took it back and had them install it so none of my headlights were working except for 1 that i tried using without the flickering device and they fixed it to get my los to work with hids those are all good. now only 1 hi beam works. what can i do to get the other to work as i soon hope to install hid highs
Don't need the anti flicker for HIDs for our 2nd gen cars. Did you try swapping bulbs to make sure it is not the bulbs? I would also take it back to the shop and point out to them that they were fine until they worked on it for you.
its solved it stopped working when they told me to use the anit flicker thingy it blew my fueses but at the time i didnt realize each hi/lo left right had an individual fuse
