1 - 13 of 13 Posts
Thanks man, I just didn't see them. If they're there, they're hidden under the fabric of the deck, because it looked like there were rises where speakers would be, but there was no grille exposing the speaker. I'll go out tomorrow and take a look. Thanks again.
i believe there a little oversize yes, but i could be wrong. to clear up your sound ( in the rear) you can do the speaker grill mod, from a first generation LHS or intrepid. simply remove the rear shelf and make a template and cut for the speaker grills. looks and sounds much better.
1st Gen FTW - It's AutoMedic!
NO idea... but I'd think so. The use of the baskets as an adapter I don't know how much I'd like that - may leave a gap around the driver and cause air passing noise - maybe seal it up with a gasket material of some sort - but this is all based on looking at pictures - I have not had to do the swap myself.
1 - 13 of 13 Posts
