1 - 9 of 9 Posts
My Check engine light just came on today and I check the fault codes and it brings up 32 "Open or shorted condtion detected in the EGR transucer solenoid circuit" What does this mean? I just had my radiator replaced a couple of weeks ago, don't know if it has anything to do with this? So any info on this fault code would be greatly appreciated.
Thanks in advance...
get off my lawn
nothing to do with the cooling system EGR (exhaust Gas Recurlation),, 9 times out of 10 the egr valve and its control unit (known as transducer)needs to be replaced,, get one from the dealer!! ive found the ones from auto zone napa etc,, arent worth a chit,,
good luck
  • Like
Reactions: Wildman
Thanks DrDodge! I appreciate the help, I have to get some other work done to it so I'll get that banged off at the same time. What's the price on a EGR valve?
It's $122 MSRP. at the dealer.
If I remeber right, the autozone part is the same as the chrysler one. It comes as a kit with the solenoid and valve.
  • Like
Reactions: Wildman
ok thanks again guys, now one more question... Is it ok to still drive my car around with this problem? It seems to run perfect right now?
Umm, I would if I had to, but not for long, I think after sometime it'll start to plug up your Cat.
Mine did the same thing and I was really frustrated because I had just done a tune up and replaced the airfilter. Turns out that I had just pulled the wire and 1 vaccuum hose loose...lol
Cats are overrated :biglaugh:
1 - 9 of 9 Posts
