OK... I finally got the valve body out and TRS installed and valve body back in car in my daughter's '95 Concorde. NOW... the gear shift seems "locked" in low. It will not budge. It feels like when the car is in park with key off. Without valve body in shifter moves easily. Shifter on valve body moves freely when out of trans.
Anyone know what is going on? Why won't the shifter move from gear to gear?
The Womanizer!
Is the shifter on the valve body in the right position when you install it? Maybe you have it all the way the wrong way?
Yep... everything is as it should be. It feels like the shifter is locked like when it's in park with the key off.
