*fixed* 'new' engine in; being worked on (pics)
<img src="http://www.steadyflow.net/pictures/intrepid/18-06-06_1328.jpg"></img><br>figured i'd have a look at the timing belt while the radiator was still out. looks nice. there's a little rust resting on the belt, but in great condition. after 5 minutes the tiny bit of rust from sitting will wear off. the belt is snug around the sprockets, so it's definately been changed recently. i see the water pump was done as well. the timing belt was probably done at the same time as the water pump or vice versa.<br>
<img src="http://www.steadyflow.net/pictures/intrepid/18-06-06_1337.jpg"></img><br>the picture is blurred, but the spark plugs were all clean like this. evidence of an engine that has been well taken care of. did i mention antifreeze that came out was bright green? no rust, discolouration; clean as a whistle. 170K kms and other than the outside of the engine being a little dusty, it's clean.<br>
<img src="http://www.steadyflow.net/pictures/intrepid/18-06-06_1338.jpg"></img><br>- water pump<br>
<img src="http://www.steadyflow.net/pictures/intrepid/18-06-06_1613.jpg"></img><br>gas line fitting. this is why auto recyclers should be kicked in the balls. part of the engine harness was chopped and as you see here, so is the gas line fitting. i ended up cutting it half open with side cutters to get it off. after spending an absorbant amount of time on one of them, i decided to change that part of the fuel rails.<br>
<img src="http://www.steadyflow.net/pictures/intrepid/18-06-06_1647.jpg"></img><br>the far left and far right pipes are the ones the chopped fittings was/is on. the left one is bent below the lip while trying to force the fitting off. yes, i know, you just press down the plastic ring on the inside.... well, it gunked up well and didn't function.<br>
<img src="http://www.steadyflow.net/pictures/intrepid/18-06-06_1722.jpg"></img><br>fuel lines re-assembled
<img src="http://www.steadyflow.net/pictures/intrepid/18-06-06_1530.jpg"></img><br>the engine harness that i had to fix. each bank has a plastic casing that holds the wires and it slides over the studs. well, sometimes people shouldn't touch cars..
<img src="http://www.steadyflow.net/pictures/intrepid/18-06-06_1529.jpg"></img><br>- magic! 4 pieces become 6!
Great White said:
I lost track of how many times I saw the same thing there. 3? 4?
What happened there?
Cheers
BJ
i'm trying to fix it. the site fuct up when i posted.. i can't seem to remove some lines? fuct up.. trying to fix. sorry.
  • Like
Reactions: Great White
