1 - 10 of 10 Posts
Just finished installing new Mopar front strut assemblies - everything but the springs which seemed fine. I did the job because a mount and bearing were bad on the driver's side. Side note: the side with the broken mount, the strut tower was not put together properly from the factory. The notch was not at 10 o'clock, more like 5:30.
Anyway, neither FSM nor the Haynes said anything about getting the front end aligned, but I've always done that after strut jobs o my other cars. I'll at least get it checked but what should I expect - is alignment necessary?
Farticcus of Plenticcus
Yes, absolutely...
Front toe was way off, everything else was in spec.
Of course the adjusting sleeves on the tie rod ends were rusted beyond recognition, so I had to replace those ...
Did you get the "Good" adjusters or just crappy OEM style replacements? LOL!
Front toe was way off, everything else was in spec...
Good you got it checked. Bad toe is what does a real job on the tires.
...Of course the adjusting sleeves on the tie rod ends were rusted beyond recognition, so I had to replace those ...
Exactly!! :)
The alignment guy knew all about it - I put on the upgraded adjustors!!!!
:yay::sohappy:
1 - 10 of 10 Posts
