just picked up our intrepid yesterday. It's a 2000 Intrepis ES with the 3.2 engine. Just love the looks of this car. I hope it runs a long time for me. I will have to do some tlc on it, the door gaskets have shrunk, so I will have to reposition them and I am going to glue them in place. Also the drivers window isn't working properly, I don't know if it is just off the track or if something is broken. I got it pretty reasonable and I knew these things were bad so I have some work ahead of me. Also the auxillary cooling fan is seized, the one that comes on with the A/C. My 96 Caravan had the same problem and I replaced that with an aftermarket fan ,. much cheaper and works good. This is a good forum, lots of good info on here. It gave me a lot of pointers on what to look for when I was shopping for a car. Good job everybody.
sounds like youve got a nice little project ahead of you there... Im sure you'll find all the answers and support you need on the boards, welcome!
Welcome to the site.
If your door seals shrunk quite a bit I would go to the wreckers and buy one seal, cut a section slightly bigger than you need and add it to yours. Your seal is a one piece seal but you can cut it, the last few years of Intrepids all had a cut seal.
Well, I worked on the door gaskets today and got them back in place. It wasn't as hard as I thought is was going to be the door gaskets were split at the bottom so I could just slide them back up and in place. I glued them now so hopefully that will help. I also used armorall so maybe they won't shrink so fast. I also noticed the drivers window doesn't go up all the way. It stopped just as it started to touch the weatherstripping on top. I took the door panel off and did some adjusting and got it too about a 1/4 inch from the top now which is better but i am still worried it will leak in the rain. Well gotta run.
Royben
