new TCM with 2.7 gears?
I'll be replacing my 3.2 SE gears with gears from a 2.7 shortly. If I want to correct the speedometer due to the final drive ratio change, the TCM needs to be replaced, correct?
If that is the case, does this module also retain the VIN of the car, and thus would need "reflashing", or is it a direct-drop swap?
thanks
thanks
