about 6 months ago i took out the stock infinity system in my 94 ES. I replaced all the speakers with
1 pair Reference Series REF5002I 5-1/4" Two-way
1 pair Reference Series REF9602I 6" x 9" Two-way
REF7541A 520 Watt 4-channel amplifier
2 1230W 12" Subwoofers
Power Handling, RMS: 300 Watts
Power Handling, Peak: 1200 Watts
Sensitivity: 92dB
Frequency Response (±3dB): 20Hz - 250Hz
Mounting Depth: 6-7/16"
Impedance: 4 Ohms
im thinking of buying this amp for the 2 12" i have right now but im thinking it might be too much power. but would be good because then i could upgrade to either the infinity KAPPA PERFECT 12.1 or KAPPA PERFECT12DVQ
REF1211A 1200 Watt Class D Subwoofer Amplifier
Specifications
CEA Rated: Yes
Power Output: 854 watts RMS x 1 channel at 4 ohms and ≤ 1% THD + N 1300 watts RMS x 1 channel at 2 ohms, 14.4V supply and ≤ 1% THD + N
Signal-to-Noise Ratio: 72 dBA (reference 1 watt into 4 ohms)
Dynamic Power: 1516 watts at 2 ohms
Effective Damping Factor: 6.357 at 4 ohms
Frequency Response (-3dB): 17Hz to 302Hz (-3dB)
Maximum Input Signal: 5.7V
Maximum Sensitivity: 260mV
Output Regulation: .132 dB at 4 ohms
MSRP U.S. $: $574.95
KAPPA PERFECT12DVQ
Specifications
MSRP U.S. $: $444.95 each
Power Handling, RMS: 400 Watts
Power Handling, Peak: 1600 Watts
Frequency Response (±3dB): 25Hz - 400Hz
Mounting Depth: 7"
Impedance: 2 or 8 Ohms depending on wiring
Sensitivity: 92dB
KAPPA PERFECT12.1
Specifications
MSRP U.S. $: 349.95
Power Handling, Peak: 1400W
Power Handling, RMS: 350W
Sensitivity: 96dB (In car)
Frequency Response (± 1.5dB): 18Hz - 150 Hz
Frequency Response (±3dB): 18Hz - 150Hz
Impedance: 4 Ohms
Mounting Depth: 6-1/2"
would i be able to upgrade to either in the future with that 1200watt amp being able to push enought power?
thanks for the help!
-india
The REF1211A would be plenty of power for any of those subs. It's a little overkill for your current subs as well as the Perfects. It's perfect for two DVQs wired for a 4ohm load though...
whats the difference between the perfect 12.1 and the DVQ's?
sorry im new to audio.
-india
-india
The DVQ is dual voice coils and more powerful.
He is correct about the Dual voice coils, but that does NOT make them more powerful. It simply changes the wiring options of the subs to match different amp OHM loads. If you pick an amp first, then let us know what you pick and we will help you get the correct sub. If you pick the sub first, we will help you get an amp that will run at the correct ohm load for that sub. The only difference between a Perfect 12.1 and a Perfect 12.1 DVC will be the final load presented to the amp.
-india
Like has been said, the main difference as far as it applies to your situation is the power handling. The DVQ has an RMS power handling of 400W vs. the Perfect having a power handling of 350W RMS. However, the Perfect has a wider ferquency response than the DVQ. The Perfects would probably handle the extra power though. Just keep the gains turned down a little...
