Hey guys here is the issue with my 300M ,I took the entire dash apart because I had no power at the cigarette lighter and I found that the wire is fine but there is no power from the fuse panel itself. What does this mean? Wires have continuity .
Also fuse 19 the one that its 10amp on 99 -2001 and 15amp in 2001-2004 pops if I put anything under 25amp. WTF happens in that fuse panel? Every wire is factory correct ,nothing is butchered or aftermarket. Is there a main ground from the fuse panel I should take care off?
I got a spare fuse panel /BCM from my 2000 300M. Are they a direct swap and what can I screw up when I change them...because with these cars there's always fix something and break 2 things while fixing one lol
Oh and since my 300M is made for Europistan I have the stupid 433Mhz RKE . Can I install a US one for the better keyfob range?
