00r/t.mopar.muscle said:The yellow should still be fused, it just isn't connected to the ignition so it is constantly on. Even if the fuse looks ok try checking it with a meter. Thats the only likely problem I can think of.
No prob, glad I could help! I went through the same thing once. I obviously checked the fuse first, but it looked fine. After checking everything else out I finally went back to the fuse and then with a meter found out it was blown. I wasted like 2hrs for nothing!DodgeyAussie said:Turned out to be a fuse that didn't even look blown... as you mentioned. Thanks for your help!
Jim Beam actually lolThe Viking said:LOL! blame it on the beer!
