Can you guys comment on what OBD2 readers are recommended? I had one of the $15-ish readers (ELM327) and bought the Torque app (so I have the full license), but I let my friend's son borrow it and never got it back. The unit I had looked pretty much like this one:
ELM327 WIFI OBD2 OBDII Auto Car Diagnostic Scanner Scan Tool For iPhone Android | eBay
I'm seeing something about 'advanced codes', and don't know if the inexpensive units will read those, or if the more expensive models are just engaging in marketing mumbo-jumbo and they'll all read 'advanced' codes.
Seeing this one on Amazon, but for $100, does it really work any better than a $20-ish unit?
https://www.amazon.com/BlueDriver-B..._1?s=automotive&ie=UTF8&qid=1430915360&sr=1-1
Your input would help. Thanks!
If you want a decent code reader you're going to need to pony up some cash for a real scanner. Not these Bluetooth BS units.
This Actron will read ABS/Airbag codes also for around $185. And read fuel trims, etc real time.
https://www.amazon.com/Actron-CP968...506915980&sr=8-4&keywords=actron+auto+scanner
Most of the cheaper ones won't do ABS or Airbag codes. Just basic Code Readers.
There's also a Harbor Freight one that's supposed to be fairly decent in this thread:
http://www.dodgeintrepid.net/128-to...harbor-freight-obdii-scanner.html#post4193674
Around $100.
Thanks for that. Turns out I pulled the trigger last night on an OBDLink LX by Scantool because it was a recommended unit on the Torque site. When I'm wealthy again enough to buy a BMW, I'll spend the $100+ on a top-notch model, but this should get me by.
Sent from my HTC 10 using Tapatalk
Read Only
I have the BlueDriver OBD Reader and I love mine it works really well and it allows you to export your scan as a document to various save locations for you to use later if you wish as well. I have Attached a screenshot of the Scan Report and Freeze Frame Data at the time the code was set just to give you an idea.
RitualJman
RitualJman
Thanks for that, but since my post, I've moved on. I'm tooling around in an M6, now. ;-)
