Anybody have an idea where I might get an OEM alarm for a 96 Concorde/Intrepid/LHS/Vision?
the oem alarm comes with the premium BCM, in my opinion, it maybe easier/cheaper to install an aftermarket alarm than to have the factory set-up.
HTH Bruce
You'ld be missing wiring in the front doors for the lock sense and wiring in the trunk for the lock cylinder knockout sense. As Dabirdz96 said it would be more feasable to go aftermarket.
There is a HOW-TO on installing the Factory Alarm in the first Gen LH car. It tells everything you need to have, and how much work is involved. Please read it and then decide if you want OEM or aftermarket.
Ok I just thought you'd have to connect it up to a harness and go. Thanks for the help aftermarket here I come.
go with the aftermarket setup. everyone who tries to hook up OEM only has horror stories to tell.
