Bad ignition switch?
That's how it's supposed to act, and mine does that. But, it's when I take the key completely out of the cylinder mine still stays on.i have that,when the car isint started the oil ligth is on and when i start the car goes away??
2.7L: Passenger side....Where is the oil pressure switch located anyways? Passenger or drivers side?
I don't think the problem is at the oil pressure switch (no problem there could cause the light to turn on if power is not simultaneously being to the other side of the light). If you look at the FSM pages I mentioned, for the light to come on, two things have to happen: (1) Power has to be applied from that fuse, and (2) The oil pressure switch has to be closed (or it's wire otherwise shorted to ground). (2) is satisfied anytime the engine is not running (oil presure drops to zero, switch closes). So for the light to be coming on when the ignition switch is off means that power has to be on the fuse line, which it wouldn't be unless the ignition contact (upstream of the fuse) failed to open like it is supposed to when you turned the ignition off - *OR* something is otherwise connecting voltage into that line.Uhm... see, I did have my brakes done the day before the problem started. Is it possible for some brake fluid to have been spilled on the oil pressure switch causing a short??
Holy flashbacks, Bill-Man!I don't think the problem is at the oil pressure switch (no problem there could cause the light to turn on if power is not simultaneously being to the other side of the light). If you look at the FSM pages I mentioned, for the light to come on, two things have to happen: (1) Power has to be applied from that fuse, and (2) The oil pressure switch has to be closed (or it's wire otherwise shorted to ground). (2) is satisfied anytime the engine is not running (oil presure drops to zero, switch closes). So for the light to be coming on when the ignition switch is off means that power has to be on the fuse line, which it wouldn't be unless the ignition contact (upstream of the fuse) failed to open like it is supposed to when you turned the ignition off - OR something is otherwise connecting voltage into that line.
