1 - 2 of 2 Posts
1999 Intrepid 2.7L engine
I recently had the oil pan gasket replaced and the oil light sensor still comes on. Yet, I have had the car looked at by 3 different mechanics, who say everything is good. Any ideas why this light won't go away? Do more problems lie ahead?
Replace the oil pressure switch on the passenger side of the block. There's a TSB about this and the installation of a vent wire. "oil light flicker" is a good thread to read. Cheap and easy fix, unless you've got other problems with oil pressure, this should solve the problem
1 - 2 of 2 Posts
