1 - 13 of 13 Posts
I first tried this on my BMW 318is and wanted to see if it worked and it did - it made my tires black for over a year.. yes it really did.. no I am not associated with the company and I am not advertising this.. it just works.
Por Glo
It does make the tire black.. unlike some other stuff I have tried including that ugly armor all that makes tires go brown. It does not wash off.. and it is best to really scrub your tires with an SOS pad first - claen the tires then apply. Now the color will always stay black - the shine does not stay past a couple months so if you want a 'shine' then yes you will have to reapply - it costs 10 bucks..
The company that makes this has no idea how good it is..
POR-15 reacts to sunlight. It will begin turning a chalky white. The product doesn't lose any of its effectiveness, just changes color.
Also, if you want your tires to stay black and looking "new", hose them down with degreaser or the same stuff you clean your rims with every time you wash the car. Let them soak for 5 minutes or so then scrub with a brush, towel, or sponge and then hose her off.
Not my experience.. I live in an area which rains 4 months + a year and super dry in the summer - temperature average 40-80 degrees. I put POR GLO on my tires and they remained black for 1.5 years. It did not turn white and I did put it on brand new Dunlop tires when I bought them. The only thing I found is they lose shine but stay black.
NOTE In the last post you talked about Por 15 -> I am talking about POR GLO not POR 15 which is for metal and rust.
I can read. In case you can't, 98ESer posted about POR-15 and I was warning everyone that when exposed to sunlight, it changes color.
I'm happy you're happy with your tire shine.
I just wanted to share my experience with it - sorry for the Por-15 mix up.. I am glad you told us about it.
ya where about could i get some of this stuff ??? ive never seen it an i frequent all the auto stores including wal mart about once a week or more so lemme know
I dont think that will be found in an auto store, maybe a home depot or something similar considering that is made for vinyl, and POR 15 makes POR GLO.....
I checked the website, here is the msds sheet and the area to order it
Order Here
________________________________________
SECTION 1: IDENTIFICATION Catalog No. (N/A)
Product Name: POR-Glo
Manufacturer Name: POR-15, Inc.
General Use: Sealer Protector
Address: P.O. Box 1235
Morristown NJ 07962-1235
Email: [email protected]
Business Phone: (800) 457-6715
Business Fax: (973) 887-8007
Emergency Phone: (973)-887-1999
For information
in North America, call: (800) 457-6715
CHEMTREC Numbers:
For emergencies in the US, call CHEMTREC: 800-424-9300
For emergencies outside US, call INTERNATIONAL: (703)527-3887
Manufacturer MSDS Revision Date: 09/15/2005
Physical Description / Properties
Physical State/Appearance: Low viscosity clear liquid
Color: Colorless
Odor: Aromatic odor.
Vapor Pressure: Not Applicable
Vapor Density: Heavier than air
Flash Point: Not Applicable
Upper Explosive Limit: Not Applicable
Lower Explosive Limit: 1.1%
Boiling Point: 139°C (282°F)
Solubility: Negligible In Water
Specific Gravity: 0.919 (Water = 1)
Evaporation Point: < 1 (Ether = 1)
Molecular Formula: Mixture
Molecular Weight: Varies
Ingredients
Chemical Name CAS# Lower Percent Upper Percent
Petroleum Solvent 64742-94-5
Eytol
To Top of page
SECTION 2 : HEALTH HAZARD INFORMATION Catalog No.: (N/A)
Health Effects
Emergency Overview: Hazardous according to criteria of Worksafe Australia
Applies to All Ingredients:
Route of Exposure: Inhalation: Yes
Eyes: Yes
Skin: Yes
Ingestion: Yes
Signs/Symptoms: High vapor concentrations may cause headaches, dizziness.
Aggravation of Pre-Existing Conditions: None known at this time.
First Aid
Eye Contact: Immediately flush eyes with plenty of water for 15 to 20 minutes occasionally lifting eyelids. Get medical attention, if irritation or symptoms of overexposure persists.
Skin Contact: Immediately wash skin with plenty of soap and water for 15 to 20 minutes, while removing contaminated clothing and shoes. Get medical attention if irritation develops or persists. Wash contaminated clothing thoroughly before re-use.
Inhalation: If inhaled, remove to fresh air. If not breathing, give artificial respiration or give oxygen by trained personnel. Seek immediate medical attention if necessary.
Ingestion: If swallowed, do NOT induce vomiting. Call a physician or poison control center immediately. Never give anything by mouth to an unconscious person. Dilute by giving 2 glasses of water to drink.
Petroleum Solvent :
Eytol :
To Top of page
SECTION 3 : PRECAUTIONS FOR USE Catalog No.: (N/A)
Engineering Controls / Personal Protection / Flammability
Engineering Controls: Use appropriate engineering control such as process enclosures, local exhaust ventilation, or other engineering controls to control airborne levels below recommended exposure limits.
Ventilation System: Use in well-ventilated areas only. Have adequate general exhaust.
Skin Protection Description: Cover as much of the exposed skin area as possible with appropriate clothing. If skin creams are used, keep the area covered to a minimum.
Hand Protection Description: Wear appropriate protective gloves. Consult glove manufacturer's data for permeability data.
Eye/Face Protection: Wear appropriate protective glasses or splash goggles as described by 29 CFR 1910.133, OSHA eye and face protection regulation, or the European standard EN 166. Contact lenses should not be worn.
Respiratory Protection: A NIOSH approved air-purifying respirator with an organic vapor cartridge or canister may be permissible under certain circumstances where airborne concentrations are expected to exceed exposure limits. Protection provided by air purifying respirators is limited. Use a positive pressure air supplied respirator if there is any potential for an uncontrolled release, exposure levels are not known, spray painting, or any other circumstances where air purifying respirators may not provide adequate protection.
Other Protective: Eyewash and deluge shower should be available.
Exposure Standards
Ingredient Guidelines
Ingredient: Eytol
Guideline Type: OSHA PEL-TWA
Guideline Type: ACGIH TLV-TWA
Guideline Type: Australian Exposure Standard
Ingredient: Petroleum Solvent
To Top of page
SECTION 4 : SAFE HANDLING INFORMATION Catalog No.: (N/A)
Storage And Transport
Handling: All containers to be grounded when in use.
Chemical Stability: Stable
Conditions to Avoid: None
Incompatibilities with Other Materials: Avoid strong oxidizing agents.
Hazardous Polymerization: Will not occur.
Hazardous Decomposition Products: Smoke, toxic vapors, fumes.
DOT Shipping Name: Non-Regulated
DOT Hazard Class: Non-Regulated
Spills And Disposal
Spill Cleanup Measures: Contain spills and leaks to prevent discharge into environment. Use sand, earth, absorbent.
Other Precautions: Keep away from children.
Waste Disposal: Consult with the US EPA Guidelines listed in 40 CFR Part 261.3 for the classifications of hazardous waste prior to disposal. Furthermore, consult with your state and local waste requirements or guidelines, if applicable, to ensure compliance. Arrange disposal in accordance to the EPA and/or state and local guidelines. Triple-rinse drum prior to offering for recycle.
Fire / Explosion Hazard
Upper Flammable or Explosive Limit: Not Applicable
Lower Flammable or Explosive Limit: 1.1%
Extinguishing Media: Use dry chemical, foam, carbon dioxide, water fog or other material suitable for surrounding materials.
Fire Fighting Instructions: Use cold water to cool fire-exposed containers.
Protective Equipment: As in any fire wear self-contained breathing apparatus pressure-demand, MSHA/NIOSH (approved or equivalent) and full protective gear.
Unusual Fire Hazards: Isolate from heat, electrical equipment, sparks, open flames.
To Top of page
OTHER INFORMATION Catalog No.: (N/A)
Applies to All Ingredients :
TSCA 8(b): Inventory Status: All ingredients are listed
Petroleum Solvent :
Eytol :
Section 313 Toxic Release Form: This product contains the following toxic chemical subject to the reporting requirements of section 313 of the emergency planning and community right to know act:
Chemical Name: Eytol
% By weight: 17.4%
Disclaimer:
This Health and Safety Information is correct to the best of our knowledge and belief at the date of its publication but we cannot accept liability for any loss, injury or damage which may result from its use. We shall ensure, so far as is reasonably practicable, that any revision of this Data Sheet is sent to all customers to whom we have directly supplied this substance, but must point out that it is the responsibility of any intermediate supplier to ensure that such revision is passed to the ultimate user. The information given in the Data Sheet is designed only as a guidance for safe handling, storage and the use of the substance. It is not a specification nor does it guarantee any specific properties. All chemicals should be handled only by competent personnel, within a controlled environment.
Should further information be required, this can be obtained through the sales office whose address is at the top of this data sheet. We welcome any additional information about our products that customers have obtained by personal experience.
References:
1. American Chemical Society, STN Easy Online Database
2. Brethericks Reactive Chemical Hazards Database. Version 2.
3. Gassarett and Doulls Toxicology, The Basic Science of Poisons.
4. Hawleys Condensed Chemical Dictionary, Thirteenth Edition
5. IARC monographs on the Evaluation of the Carcinogenic Risk of Chemicals to Man, WHO International Research on Cancer.
6. Industrial Hygiene and Toxicology, by F.A. Patty.
7. National Library of Medicine, Department of Health and Human Services, Hazardous Substances Data Bank (HSDB).
8. National Toxicology Program (NTP) Eighth Report on Carcinogens, 1997.
9. NIOSH Registry of Toxic Effects of Chemical Substances (RTECS) and Pocket Guide to Chemical Hazards.
10. OSHA Hazard Communication Standard, 1910.1200 and Z Tables.
11. Sax Dangerous Properties of Industrial Materials. Tenth Edition.
12. The Merck Index: An Encyclopedia of Chemicals and Drugs. Merck and Company. Twelfth Edition 1998.
13. Threshold Limit Values for Chemical Substances and Physical Agents in the Work Environmental and Biological Exposure Indices. TLV Booklet, 2001.
Government Listings: NG - Negligible
NA - Not Applicable
NE - Not Established
UN - Unavailable
ND - Not Determined
Copyright© 1996-2006 Actio Software Corporation. All Rights Reserved.
No I have never used this stuff, just thought people would like to have all of the information up front.
Discussion Starter #13
I like it and would continue to use it.. you will lose shine after about a month.. but the tires stay black for about eight months here.. (lot's of rain in the winter here.)
1 - 13 of 13 Posts
