I plugged in the OTIS (using the entire harness from the donor car) tonight to see if it works and its fine except for the odometer reading, it reads --:--, did I fail to hook something up correctly? It seems that there are a lot of extra connections on the harness. The other thing is what is the fastest way and easiest way to cut the headliner? I'd really like to do this install myself instead of taking it the mechanic.
Thanks,
BK
Thanks,
BK
