Only issue I've run into is that the connector is on the left side of the OTIS but the right side of the EVIC. Wiring harness was a little tight trying to reach the EVIC's connector. That's about it.
That rhythm is INFECTIOUS.
This.
I ended up going to the yard and cutting the tail off of one and extending my own, instead of trying to replace that whole harness.
This.
Thanks, I will be doing the change probably Friday and I did take a good portion of the wiring just in case I have the same problem
